跳转到主内容
Panasonic Lumix DMC-ZS25 Screen Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: 步骤 3 中的图像 1,3 Panasonic Lumix DMC-ZS25  Screen Replacement: 步骤 3 中的图像 2,3 Panasonic Lumix DMC-ZS25  Screen Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-ZS25  Screen Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the screen using the plastic opening tool as shown.
结论
3等其他人完成本指南。
Abbas Khan
于01/21/15注册
482 声望
创作了4篇指南
团队
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 的会员
USFT-BROWN-W15S9G5
3 名成员
创作了7篇指南
一条评论
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,364
