跳转到主内容
Panasonic Lumix DMC-ZS25 Power Button Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: 步骤 1 中的图像 3,3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Open it gently to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 3 中的图像 1,2 Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to detach the ribbon cable.
    • Be careful when you use the spudger because you do not want to break the the ribbon.
  4. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 4 中的图像 1,3 Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 4 中的图像 2,3 Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 4 中的图像 3,3
    • Remove the button board using the plastic opening tool.
    • Remove the screen. Lift the screen from the right hand side.
    • After your hear a "click" sound, you have successfully opened the screen.
  5. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 5 中的图像 2,2
    • Remove the two black screws that are located beneath the screen.
    • Lift the metal cover using the plastic opening tool.
  6. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opener to remove the side covers.
  7. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 7 中的图像 1,2 Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 7 中的图像 2,2
    • After removing the side covers, you will be able to take away the front cover with your hands.
    • Do not apply too much pressure on the outer cover of your device to avoid damage.
  8. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 8 中的图像 1,1
    • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
  9. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 9 中的图像 1,1
    • Remove the top cover using the plastic opening tool.
  10. Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 10 中的图像 1,3 Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 10 中的图像 2,3 Panasonic Lumix DMC-ZS25  Power Button Replacement: 步骤 10 中的图像 3,3
    • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
结论
另外一个人完成了本指南。
Abbas Khan
于01/21/15注册
482 声望
创作了4篇指南
团队
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 的会员
USFT-BROWN-W15S9G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 8
总计 578
