简介
Step by step guide to replacing your digital camera door.
你所需要的
Remove the battery and memory card from the unit
Remove 6 (0.3mm) screws from the sides of the unit
Remove 5 (0.3mm) screws from the bottom of the unit
Pull out door pin using needle nose pliers or other tool.
Notice spring positioning. This will help you re-install your replacement door
即将完成!
结论
另外一个人完成了本指南。
