跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix DMC-TZ5 button board Replacement
你所需要的
  1. Panasonic Lumix DMC-TZ5 button board Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the battery and memory card from the device.
  2. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 2 中的图像 1,1
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 3 中的图像 1,1
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 4 中的图像 1,1
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 5 中的图像 1,1
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 6 中的图像 2,2
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 7 中的图像 1,1
    • Remove the back casing from the camera.
  8. Panasonic Lumix DMC-TZ5 button board Replacement, button board: 步骤 8 中的图像 1,2 Panasonic Lumix DMC-TZ5 button board Replacement, button board: 步骤 8 中的图像 2,2
    • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
    • Carefully remove the function switch cover. This unit snaps on and off.
  9. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 9 中的图像 1,1
    • Carefully unsnap the front logic board from the rear logic board using a spudger.
  10. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 10 中的图像 2,2
    • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  11. Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 11 中的图像 1,3 Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 11 中的图像 2,3 Panasonic Lumix DMC-TZ5 button board Replacement: 步骤 11 中的图像 3,3
    • This step is only necessary if you want to separate the upper part from the button board.
    • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
    • This leaves you with the logic board and the top connection panel separate and free from the camera
结论
Ben Canfield
于10/10/10注册
424 声望
创作了3篇指南
团队
Cal Poly, Team 9-21, Regan Fall 2010 Cal Poly, Team 9-21, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G21
4 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 28
总计 6,082
