简介
The front casing is the frontal frame on your Panasonic Lumix DMC-TZ5. All the major components of the camera are attached to this front casing.
你所需要的
Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
Carefully remove the function switch cover. This unit snaps on and off.
Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
Use the spudger to unclip the top ribbon cable from the circuit board.
After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
First you must remove two 3.5mm blue screws near the hole of the lens that attach the inner casing.
2等其他人完成本指南。
