当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove 4 screws from the right side of the camera.
There are two 3.4mm screws at the top.
There are two 2.2mm screws at the bottom.
Remove 5 screws from the base of the camera.
There are two 2.2mm screws next to the battery compartment.
There are three 4mm screws around the tripod mount.
Detach both ribbon cables using a spudger.
Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Remove the 3 screws holding the lens assembly in place.
The two screws on the left are 4.5mm with washers.
The single screw on the right is 4mm.
Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
First you must remove two 3.5mm blue screws near the hole of the lens that attach the inner casing.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
