跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement
你所需要的
    1. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Remove the battery and memory card from the device.
      询问修复机器人
      添加评论
    2. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 2 中的图像 1,1
      • Remove 4 screws from the right side of the camera.
      • There are two 3.4mm screws at the top.
      • There are two 2.2mm screws at the bottom.
      询问修复机器人
      添加评论
    3. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 3 中的图像 1,1
      • Remove the single 3.4mm screw on the left side of the camera.
      询问修复机器人
      添加评论
    4. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 4 中的图像 1,1
      • Remove 5 screws from the base of the camera.
      • There are two 2.2mm screws next to the battery compartment.
      • There are three 4mm screws around the tripod mount.
      询问修复机器人
      添加评论
    5. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 5 中的图像 1,1
      • Slowly slide the back cover away from the device
      • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
      询问修复机器人
      添加评论
    6. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 6 中的图像 2,2
      • Detach both ribbon cables using a spudger.
      • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
      询问修复机器人
      添加评论
    7. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 7 中的图像 1,1
      • Remove the back casing from the camera.
      询问修复机器人
      添加评论
    1. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement, button board: 步骤 8 中的图像 1,2 Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement, button board: 步骤 8 中的图像 2,2
      • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
      • Carefully remove the function switch cover. This unit snaps on and off.
      询问修复机器人
      添加评论
    2. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 9 中的图像 1,1
      • Carefully unsnap the front logic board from the rear logic board using a spudger.
      询问修复机器人
      添加评论
    3. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 10 中的图像 2,2
      • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
      询问修复机器人
      添加评论
    4. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 11 中的图像 1,3 Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 11 中的图像 2,3 Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 11 中的图像 3,3
      • This step is only necessary if you want to separate the upper part from the button board.
      • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
      • This leaves you with the logic board and the top connection panel separate and free from the camera
      询问修复机器人
      添加评论
    1. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement, Camera Lens Assembly: 步骤 12 中的图像 1,1
      • Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
      询问修复机器人
      添加评论
    2. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 13 中的图像 1,1
      • Remove the 3 screws holding the lens assembly in place.
      • The two screws on the left are 4.5mm with washers.
      • The single screw on the right is 4mm.
      询问修复机器人
      添加评论
    3. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 14 中的图像 1,1
      • Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
      询问修复机器人
      添加评论
    4. Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 15 中的图像 1,2 Panasonic Lumix DMC-TZ5 Camera Lens Assembly Replacement: 步骤 15 中的图像 2,2
      • Remove the entire assembly out of the casing.
      • The ribbons on the left and bottom of the assembly simply rest on the camera housing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
15等其他人完成本指南。
Brandon
于10/11/10注册
586 声望
撰写一个指南
团队
Cal Poly, Team 9-21, Regan Fall 2010 Cal Poly, Team 9-21, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G21
4 名成员
创作了84篇指南
1指南评论
I have a Lumix, not sure if it is this one, but I now have a MUCH better idea on how to proceed. I was knocked off a shelf(in case) and fell about five feet to the floor. Dang CAT! It powers on and (if I recall) will still capture an image but the display is simply white. This tells me most of the camera is functioning and the ribbon cable has become disconnected.(I hope)
I have looked for this info before and have no idea why it did not show up on DDG, Google, or SP. Thank you for this guide.
T Bob Trasman
T Bob Trasman - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 57
总计 27,187
