跳转到主内容
Panasonic Lumix DMC-GX85 Eye Sensor Replacement
你所需要的
  1. Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Rear Cover: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Rear Cover: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Rear Cover: 步骤 1 中的图像 3,3
    • Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
  2. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 2 中的图像 1,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 2 中的图像 2,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 2 中的图像 3,3
    • Using a spudger, gently lift the forward end of the shoe spring to disengage its locking mechanism.
    • While holding the forward end of the shoe spring up, push from its lifted end to remove the shoe spring.
  3. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 3 中的图像 1,2 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 3 中的图像 2,2
    • Remove the two 6.0mm silver Phillips #0 screws closest to the display screen.
    • Do not remove the two forward-most silver screws.
  4. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 4 中的图像 2,2
    • Turn the camera so the side with the jack cover is facing you.
    • Near the camera's top end, remove the 4.0mm black Phillips #0 screw on the bottom in this orientation.
    • Open the jack cover and remove the 4.0mm black Phillips #0 screw inside.
  5. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 5 中的图像 2,2
    • Flip the camera upside down so the bottom of the camera is facing you.
    • Remove the two center 2.5mm black Phillips #0 screws.
    • Remove the outer 4.5mm black Phillips #0 screw.
  6. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 6 中的图像 1,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 6 中的图像 2,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 6 中的图像 3,3
    • Turn the camera so the display screen is facing you.
    • Rotate the top of the screen away from the camera body to access and remove the 4.5mm black Phillips #0 screw.
    • Remove the rear camera cover by gently pulling from the top side.
    • When removing the rear cover, pull apart slowly to prevent damaging the ribbon cable connecting the display screen and the Sub PCB.
  7. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 7 中的图像 1,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 7 中的图像 2,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 7 中的图像 3,3
    • Turn the camera so the lens is facing down with the rear cover pulled back.
    • Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
    • Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
    • Do not bend the ribbon cable excessively and take care not to damage the ribbon cable.
  8. Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Viewfinder: 步骤 8 中的图像 1,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Viewfinder: 步骤 8 中的图像 2,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Viewfinder: 步骤 8 中的图像 3,3
    • Remove the 4.5mm black Phillips #0 screw under the viewfinder.
    • Gently pull the viewfinder cover from the camera.
  9. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 9 中的图像 1,2 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 9 中的图像 2,2
    • Remove the 2.5mm silver Phillips #0 screw located below the viewfinder.
    • Remove the ribbon cable from the underside of the camera by unlatching the black locking tab with an iFixit opening tool then pulling the ribbon away from the connector.
  10. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 10 中的图像 1,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 10 中的图像 2,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 10 中的图像 3,3
    • Remove the small ribbon cable by gently pulling it away from the camera with ESD safe tweezers.
    • Remove the viewfinder from the camera body.
  11. Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Eye Sensor: 步骤 11 中的图像 1,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Eye Sensor: 步骤 11 中的图像 2,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement, Eye Sensor: 步骤 11 中的图像 3,3
    • Hold the viewfinder with the ribbon cables facing up and towards you.
    • Remove the black 4.5mm screw Phillips screw from the bottom of the viewfinder.
  12. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 12 中的图像 1,2 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 12 中的图像 2,2
    • Pull the silver bracket away from the viewfinder unit.
  13. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 13 中的图像 1,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 13 中的图像 2,3 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 13 中的图像 3,3
    • Turn the viewfinder sideways so the cable ends and viewfinder focus wheel are facing you.
    • Remove the 3.5mm silver Phillips #0 screw from the center of the focus wheel.
    • Remove the focus wheel.
  14. Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 14 中的图像 1,2 Panasonic Lumix DMC-GX85 Eye Sensor Replacement: 步骤 14 中的图像 2,2
    • With tweezers, gently pull the eye sensor away from the viewfinder unit.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 24
总计 1,048
