简介
This guide requires careful handling of the inner parts of the camera. One needs a screw driver and spudger tool to open the camera and remove its parts.
你所需要的
On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
Using your fingers, push down on the small, metal hooks that are a part of the metal cover and attach on top of the LCD screen.
2等其他人完成本指南。
一条评论
In Step 3 above, you definitely need to remove the hot shoe cover, and the 4 screws underneath that in order to remove the back of the camera safely! If you don’t, the back cover only comes off with excessive force and then causes damage to the portion of the bracket holding it in place beneath the hot shoe - trust me, I know from experience.
