跳转到主内容
Panasonic Lumix DMC-GF2 Front Cover Replacement
你所需要的
  1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Front Cover Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-GF2 Front Cover Replacement: 步骤 2 中的图像 2,2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: 步骤 3 中的图像 1,3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: 步骤 3 中的图像 2,3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: 步骤 3 中的图像 3,3
    • Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
    • To loosen a screw, turn the screwdriver to the left. To tighten a screw, turn the screwdriver to the right.
  4. Panasonic Lumix DMC-GF2 Front Cover Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove four black 2.69 mm screws from the front of the camera.
  5. Panasonic Lumix DMC-GF2 Front Cover Replacement: 步骤 5 中的图像 1,1
    • Using your hand, gently lift up the front cover and separate it from the camera.
结论
Nicole Gerlach
于10/30/16注册
218 声望
撰写一个指南
团队
Baylor, Team 5-9, Williams Fall 2016 Baylor, Team 5-9, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G9
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 26
总计 1,034
