跳转到主内容
简介
This guide requires careful handling of the camera's inner parts, including the ZIF ribbons that attach the back cover to the camera and the buttons that will be removed.
配件
没有特定配件。
  1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Battery: 步骤 1 中的图像 1,1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 2 中的图像 2,2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 步骤 3 中的图像 1,3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 步骤 3 中的图像 2,3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
  4. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 4 中的图像 1,3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 4 中的图像 2,3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 4 中的图像 3,3
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
  5. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 5 中的图像 1,1
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
  6. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
  7. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 7 中的图像 1,1
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
  8. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 8 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
  9. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 9 中的图像 1,1
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
  10. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: 步骤 10 中的图像 2,2
    • Push on the back panel buttons from the frontside of the back cover.
    • There might be some adhesives holding the back panel buttons to the cover. Extra force may be necessary.
结论
Kingsley East
于2016年10月30日注册
456 声望分
创作了4篇指南
团队
Baylor, Team 5-9, Williams Fall 2016 Baylor, Team 5-9, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G9
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 472
