跳转到主内容
Panasonic Lumix DMC-GF2 Back Cover Replacement
你所需要的
  1. Panasonic Lumix DMC-GF2 Back Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: 步骤 3 中的图像 2,3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
  4. Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 4 中的图像 1,3 Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 4 中的图像 2,3 Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 4 中的图像 3,3
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
  5. Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 5 中的图像 1,1
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
  6. Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
  7. Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 7 中的图像 1,1
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
  8. Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 8 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
  9. Panasonic Lumix DMC-GF2 Back Cover Replacement: 步骤 9 中的图像 1,1
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
结论
Kingsley East
于10/30/16注册
462 声望
创作了4篇指南
团队
Baylor, Team 5-9, Williams Fall 2016 Baylor, Team 5-9, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G9
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,033
