跳转到主内容
Panasonic Lumix DMC-G5 Motherboard Replacement
你所需要的
  1. Panasonic Lumix DMC-G5 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove four JIS #000 screws from the bottom part of the camera.
  2. Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove two JIS #000 screws from both sides of the camera.
  3. Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove two JIS #000 screws under the viewfinder.
  4. Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the viewfinder lid.
    • Then, remove the two JIS #000 screws on the viewfinder.
  5. Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 5 中的图像 1,3 Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 5 中的图像 2,3 Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Gently remove the back panel from the camera.
    • Unclip the ribbon cable from the motherboard using Wide Plastic Opening Tools and pull the cable gently.
  6. Panasonic Lumix DMC-G5 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove the JIS #000 screws on the motherboard.
  7. Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 7 中的图像 1,2 Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Unclip the ribbon cable using the Wide Plastic Opening Tool on the motherboard.
    • Gently pull out the cable.
  8. Panasonic Lumix DMC-G5 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull out the motherboard from the camera.
结论
Khairul Samsudin
于05/22/19注册
412 声望
创作了4篇指南
团队
IUPUI, Team S1-G4, Harley Summer 2019 IUPUI, Team S1-G4, Harley Summer 2019 的会员
IUPUI-HARLEY-SU19S1G4
3 名成员
创作了8篇指南
一条评论
Dear Khairul Samsudin - this is great, thank you so much.
Can I ask about another classic repair for the Lumix G5?
As with many lumix cameras, the rear thumbwheel on the Lumix G5 is a weak point and frequently fails - usually the “push in” movement that should change functions failes in the “pushed in” position.
Plese can you see if you can create a “fix” for this? It classically fails at about year 2-3, when the camera is out of warranty and the repairs cost from Panasonic is more than a secondhand G5 on eBay will cost!
Best wishes - Paul in the UK
Paul C - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 1,413
