跳转到主内容
Panasonic Lumix DMC-G5 LCD Replacement
你所需要的
  1. Panasonic Lumix DMC-G5 LCD Replacement, LCD: 步骤 1 中的图像 1,2 Panasonic Lumix DMC-G5 LCD Replacement, LCD: 步骤 1 中的图像 2,2
    • Use J0 screwdriver to remove the two 3.2 mm screws from the outside of the assembly.
    • Use the J0 screwsdriver to remove the two 5.6 mm screws from the inside of the face near the swivel.
    • Rotate the face to more easily gain access to the screws.
  2. Panasonic Lumix DMC-G5 LCD Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-G5 LCD Replacement: 步骤 2 中的图像 2,2
    • Slide the wide plastic opening tool underneath the crack of the side of the face and separate the components.
  3. Panasonic Lumix DMC-G5 LCD Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the filament connections from the LCD backing by lifting the black lever up first on the connector, then pulling gently outward from the LCD backing with your fingers.
    • Replace the filament connections into the backing of the new LCD face to complete replacement..
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-3, Kass Spring 2017 USF Tampa, Team 1-3, Kass Spring 2017 的会员
USFT-KASS-S17S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 2,018
