跳转到主内容
Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement
你所需要的
  1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 步骤 1 中的图像 3,3
    • Remove the four 4.6mm J000 Phillips screws from the sides and two 3.2mm J000 Phillips screws along the bottom.
  2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 2 中的图像 1,3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 2 中的图像 2,3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 2 中的图像 3,3
    • Remove the two 3.2mm J000 Phillips screws located on the bottom edge of the viewfinder cover.
    • Carefully remove the viewfinder cover.
    • Remove the two 4.4mm J000 Phillips screws located near the top edge of the viewfinder.
  3. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 3 中的图像 1,3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 3 中的图像 2,3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 3 中的图像 3,3
    • Slide the Wide Plastic Opening Tool upwards along the underside of the rear casing.
    • Be careful not to disconnect the filament connections. Reinserting them can be difficult.
    • Slowly lower the casing into the position shown.
  4. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 4 中的图像 2,2
    • Use the Screwdriver J000 Phillips Head to remove the screw located at the lower-left corner of the face of the viewfinder glass.
    • Carefully lift the L-shaped clicker underneath the previously removed screw.
  5. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 步骤 5 中的图像 2,2
    • Slide the faulty diopter adjustment dial off the rod.
    • Replace the diopter dial with a 1-cm wheel.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-3, Kass Spring 2017 USF Tampa, Team 1-3, Kass Spring 2017 的会员
USFT-KASS-S17S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 21
总计 1,054
