跳转到主内容
Panasonic Lumix DMC-FZ35 LCD Replacement
你所需要的
  1. Panasonic Lumix DMC-FZ35 LCD Replacement, Clear compartment: 步骤 1 中的图像 1,1
    • Remove the battery and memory card from the unit.
  2. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove side screws: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove side screws: 步骤 2 中的图像 2,2
    • Remove 1 screw (0.4mm) from left side of unit
    • Remove 1 screw (0.4mm) from right side of unit near Strap bar.
    • Remove 1 screw (0.6mm) from right side of unit next to usb door
  3. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove Screws from Bottom: 步骤 3 中的图像 1,1
    • Remove 3 Screws from bottom of unit
    • Remove 2 (0.6mm) screws next to door
    • Remove 1 (0.4mm) screw opposite of door
  4. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove top screw: 步骤 4 中的图像 1,1
    • Raise the Pop-Up flash by pushing the flash button.
    • Remove the screw (0.6mm) from underneath the flash assembly.
  5. Panasonic Lumix DMC-FZ35 LCD Replacement, Accessing the flex cables: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-FZ35 LCD Replacement, Accessing the flex cables: 步骤 5 中的图像 2,2
    • Please be careful. Do not lift the cover fully because it is still attached to the Main Board via flex cables.
    • Lift the cover slightly as shown in picture # 1
    • Tilt the back cover as shown in picture #2. Be careful because the flex cables are still attached.
  6. Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: 步骤 6 中的图像 1,3 Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: 步骤 6 中的图像 2,3 Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: 步骤 6 中的图像 3,3
    • Flip up LCD cable clamp with a spudger or other tool.
    • Flip up backlite cable clamp with a spudger or other tool
    • Removal of the mic wire is optional. My suggestion is to leave it attached. The mic can get damaged if you pull on the wire.
  7. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: 步骤 7 中的图像 1,3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: 步骤 7 中的图像 2,3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: 步骤 7 中的图像 3,3
    • Remove the 2 screws (0.4mm) that are holding the mic assembly
    • Next step (shown in picture #2) remove the metal mic hold part.
    • Next step (shown in picture #3) use a spudger to pry off the mic. Careful not to damage the wiring.
  8. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: 步骤 8 中的图像 1,3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: 步骤 8 中的图像 2,3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: 步骤 8 中的图像 3,3
    • Release the hold clips that hold the LCD retainer in place.
    • Remove the LCD metal retainer plate as shown in picture #2
    • Remove the LCD as shown in picture # 3
  9. Panasonic Lumix DMC-FZ35 LCD Replacement, Swap out Old LCD: 步骤 9 中的图像 1,1
    • Swap out your old LCD with the new one.
    • If your backlite is ok you can buy only the LCD Display. But it is easier to purchase the LCD with the backlite attached. Replacement LCD Display VYQ5034
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,522
