简介
Step by step guide to replacing your damaged LCD Display Screen.
你所需要的
Remove 1 screw (0.4mm) from left side of unit
Remove 1 screw (0.4mm) from right side of unit near Strap bar.
Remove 1 screw (0.6mm) from right side of unit next to usb door
Remove 3 Screws from bottom of unit
Remove 2 (0.6mm) screws next to door
Remove 1 (0.4mm) screw opposite of door
Raise the Pop-Up flash by pushing the flash button.
Remove the screw (0.6mm) from underneath the flash assembly.
Lift the cover slightly as shown in picture # 1
Tilt the back cover as shown in picture #2. Be careful because the flex cables are still attached.
Flip up LCD cable clamp with a spudger or other tool.
Flip up backlite cable clamp with a spudger or other tool
Removal of the mic wire is optional. My suggestion is to leave it attached. The mic can get damaged if you pull on the wire.
Remove the 2 screws (0.4mm) that are holding the mic assembly
Next step (shown in picture #2) remove the metal mic hold part.
Next step (shown in picture #3) use a spudger to pry off the mic. Careful not to damage the wiring.
Release the hold clips that hold the LCD retainer in place.
Remove the LCD metal retainer plate as shown in picture #2
Remove the LCD as shown in picture # 3
Swap out your old LCD with the new one.
If your backlite is ok you can buy only the LCD Display. But it is easier to purchase the LCD with the backlite attached. Replacement LCD Display VYQ5034
另外一个人完成了本指南。
