简介
If your camera's screen cracks or continuously stays black, you may need to replace it. In this guide you will unscrew several screws, pry open the plastic screen casing, and detach an electronic ZIF connector ribbon to remove your glass screen. See this technique on disconnecting ZIF connectors to better learn how to detach a ZIF connector ribbon.
你所需要的
Swing out the screen on the back of your camera by 90 degrees.
Remove the two 2.2 mm Phillips #00 screws on the outside edge of the screen.
6等其他人完成本指南。
5条评论
thank for this tuto... my screen is dark , so I use it to see if it was a problem of bad contact.. unfortunatly not !...
I just had somes difficulties to understand how to rebuild the screen ( the screen axle in the empty plastic casing first and then, the screem in the plastic casing, all on a table to have our 2 hands to reconnect the connector ribbon...
thank you
Thank you for this tutorial. I dropped my camera and the screen cracked. I bought a screen from a vendor on eBay. [|The screen needed another ZIF connector to disconnect and connect, which is not shown in this titorial. But I figured that out.]
Is this screen used in any other device where the price for ‘that device’ is a lot less than this FZ1000 screen? I can’t wrap my head around why a replacement LCD is so expensive. Even without backlight. And the display board is $150+ Just robbery.
Thank you for sharing, Screen is now working , great content - thanks Kevin
