本指南有最近更改,您可查看未经巡查的最新版本。
简介
If your camera begins malfunctioning, you may need to replace your motherboard. In this replacement guide you will first remove the battery to avoid getting shocked while working inside the camera. Then you will remove the back panel, unscrew several screws, and detach several electronic ZIF connector ribbons to replace the motherboard. See this technique on disconnecting ZIF connectors to better learn how to detach a ZIF connector ribbon.
你所需要的
Slide the switch on the bottom of your camera from the right (LOCK) to the left (OPEN).
Push in on the SD card inside the battery housing.
Pull out the SD card.
Close the battery housing door.
Remove the two 5.2 mm Phillips #00 screws that are 1) below the label and 2) above the tripod mount hole on the bottom of the camera.
Remove the two 5.5 mm Phillips #00 screws on the side of the camera with the MIC jack.
Remove the two 7.0 mm Phillips #00 screws that are 1) above and 2) below the HDMI panel.
8等其他人完成本指南。
3条评论
Where do you buy a motherboard for this camera?
This article is useless, since the motherboards are not available anywhere.
Actually, Panasonic does have the part for sale. <https://panasonic.encompass.com/item/102...>
