跳转到主内容
Panasonic Lumix DMC-FZ1000 Motherboard Replacement
你所需要的
  1. Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the switch on the bottom of your camera from the right (LOCK) to the left (OPEN).
    • The battery door will swing open.
  2. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pull down on the lever that holds the battery.
    • The battery will pop out of its casing.
  3. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Pull out the battery.
  4. Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Push in on the SD card inside the battery housing.
    • The SD card will pop out.
    • Pull out the SD card.
    • Close the battery housing door.
    Il faut modifier “Étape 4 Carte mère” par “Étape 4 Carte mémoire”, mais je n’y arrive pas.
    Jojo Demonnom - 回复
  5. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 5 中的图像 1,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 5 中的图像 2,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the two 5.2 mm Phillips #00 screws that are 1) below the label and 2) above the tripod mount hole on the bottom of the camera.
    • You may ignore the screw below the tripod mount hole.
    • Remove the two 5.5 mm Phillips #00 screws on the side of the camera with the MIC jack.
    • Remove the two 7.0 mm Phillips #00 screws that are 1) above and 2) below the HDMI panel.
    • You may ignore the screw that goes through the leather material to the right of the HDMI panel.
    Quitar también los Phillips #?? zona de abajo del visor, desmontar ,y , quitar otros 2 phillips #?? interiores.
    blufs - 回复
    • There are two screws that hold the eye piece on to the main housing, just underneath. Remove these. Once these have been removed, gently pull and remove the eye piece and remove the now accessible top two screws.
  6. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 7 中的图像 1,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 7 中的图像 2,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Do not yank off the back plate. If you do, you will tear the electronic ribbons attached to the inside of the camera and the back plate.
    • Gently lift up the back plate, being careful not to damage any ribbons.
    • Do not yank out the electronic ribbons attached to the motherboard and the back plate, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Pull to disconnect from the motherboard the two ZIF connector ribbons attached to the back plate.
    • Set aside the back plate.
    The eyepiece needs to be removed!
    Remove the phillips screws from the bottom of the eyepiece, remove the eyepiece and remove the two screws at the top of the eyepiece
    bailout00 - 回复
  7. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Do not yank out the electronic ribbons attached to the motherboard, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Pull to disconnect from the motherboard the seven ZIF connector ribbons.
  8. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the four 5.2 mm Phillips #00 screws at the corners of the motherboard.
  9. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 10 中的图像 1,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 10 中的图像 2,3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Firmly grasp the left side of the motherboard.
    • Pull out the motherboard.
    • If you find it difficult to remove the motherboard, pull it away from the HDMI panel while pulling it out.
    FZ1000 MK2: I could not remove the motherboard by itself but it came off easily together with the metal plate.
    Francesco Nardone - 回复
结论
8等其他人完成本指南。
Robseth Taas
于01/07/16注册
1,781 声望
创作了5篇指南
团队
Cal Poly, Team 70-5, Forte Winter 2016 Cal Poly, Team 70-5, Forte Winter 2016 的会员
CPSU-FORTE-W16S70G5
4 名成员
创作了15篇指南
3条评论
Where do you buy a motherboard for this camera?
Pekka Liemola - 回复
This article is useless, since the motherboards are not available anywhere.
Pete Schliebner - 回复
Actually, Panasonic does have the part for sale. <https://panasonic.encompass.com/item/102...>
Jeffry Long - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 66
总计 6,929
