跳转到主内容
Panasonic Lumix DMC-FX9 Selector Buttons Replacement
你所需要的
  1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement, Selector Buttons: 步骤 1 中的图像 1,1
    • Make sure the power is off by switching the power switch to the left.
  2. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
  3. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
  4. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
    • Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
  5. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 5 中的图像 2,2
    • Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
    • Remove the LCD Screen from the glass frame carefully with the opening tool.
  6. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 步骤 6 中的图像 2,2
    • Push on the back panel buttons on the front side to remove the buttons.
    • Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 292
