你所需要的
Make sure the power is off by making sure the switch is to the right. The power switch can be found on the top side of the camera.
Use the Philips #00 Screwdriver to remove the screws on the bottom side of the camera.
Make sure to grasp the camera because these are the last two screws that hold the camera in place.
Carefully place the opening tool between the two covers and gently apply force upward to separate the covers.
即将完成!
结论
