跳转到主内容
Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement
你所需要的
  1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement, Loose Digitizer Cable: 步骤 1 中的图像 1,1
    • Power off your device by locating the on/off switch on top of camera.
  2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 2 中的图像 1,3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 2 中的图像 2,3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 2 中的图像 3,3
    • Remove the screw located on the right side of the camera.
    • Remove the screw located on the bottom right of the camera, and remove the cover from the camera.
  3. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the screw located on the base of the camera.
  4. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 4 中的图像 1,1
    • Pry the top part of the camera slowly. Be careful not to tear the digitilizer cable.
  5. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 5 中的图像 2,2
    • Open the bigger clamp using a spudger or other tools. Repeat for the smaller clamp.
  6. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 6 中的图像 2,2
    • Carefully take the thin ribbon and insert cable end into the latch. Do this for both sides.
  7. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 7 中的图像 1,3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 7 中的图像 2,3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: 步骤 7 中的图像 3,3
    • Once the ribbon is placed into the latch, carefully close the clamps by lowering the clamp into a down position. Repeat this step for both sides.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 350
