跳转到主内容
Panasonic Lumix DMC-FX37 Disassembly
你所需要的
  1. Panasonic Lumix DMC-FX37 Disassembly, Panasonic Lumix DMC-FX37 Disassembly: 步骤 1 中的图像 1,2 Panasonic Lumix DMC-FX37 Disassembly, Panasonic Lumix DMC-FX37 Disassembly: 步骤 1 中的图像 2,2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 Disassembly: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-FX37 Disassembly: 步骤 2 中的图像 2,2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 Disassembly: 步骤 3 中的图像 1,2 Panasonic Lumix DMC-FX37 Disassembly: 步骤 3 中的图像 2,2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 Disassembly: 步骤 4 中的图像 1,3 Panasonic Lumix DMC-FX37 Disassembly: 步骤 4 中的图像 2,3 Panasonic Lumix DMC-FX37 Disassembly: 步骤 4 中的图像 3,3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 Disassembly: 步骤 5 中的图像 1,1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
结论
团队
Baylor, Team S2-G3, Johnson Spring 2018 Baylor, Team S2-G3, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 644
