跳转到主内容
Panasonic Lumix DMC-FX07 Motherboard Replacement
你所需要的
  1. Panasonic Lumix DMC-FX07 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 Motherboard Replacement, Memory Card: 步骤 3 中的图像 1,1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 Motherboard Replacement, Back Cover: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-FX07 Motherboard Replacement, Back Cover: 步骤 4 中的图像 2,2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 6 中的图像 1,3 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 6 中的图像 2,3 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 7 中的图像 1,3 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 7 中的图像 2,3 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Panasonic Lumix DMC-FX07 Motherboard Replacement, Top Cover: 步骤 8 中的图像 1,2 Panasonic Lumix DMC-FX07 Motherboard Replacement, Top Cover: 步骤 8 中的图像 2,2
    • Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
    • Be careful not to damage the cylindrical capacitor on the circuit board under the top cover.
  9. Panasonic Lumix DMC-FX07 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Remove the small screw in the hole towards the top of the camera(#00P, 5.4mm).
  10. Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Use the spudger to lift up the back logic board.
    • Using your fingers, gently wiggle and pull off the back motherboard.
    • You will hear a click when you lift it up.
  11. Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the small screw holding down the lower motherboard(#00P, 3.2mm).
  12. Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 12 中的图像 1,3 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 12 中的图像 2,3 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Use the spudger to lift the upper tab from the main housing.
    • Gently lift the lower tab from the main body by prying it with your finger.
    • Gently pull off the plastic motherboard housing sideways.
  13. Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 13 中的图像 1,3 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 13 中的图像 2,3 Panasonic Lumix DMC-FX07 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Gently lift the tabs on the ZIF connectors connecting the lens to the front motherboard.
    • Once you lift the tabs the ribbons should fall right out and the front motherboard should be free.
结论
Karissa
于04/13/12注册
50 声望
创作了8篇指南
团队
Cal Poly, Team 6-23, Amido Spring 2012 Cal Poly, Team 6-23, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G23
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,396
