当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Open the battery latch, and slide the battery release lever to the right.
Remove the battery from the camera.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
Remove the left side casing.
Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
Remove the bottom right panel.
Gently remove the back casing.
Start at the bottom and carefully pry towards the top to get this piece free.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与5其他贡献者
于10/11/10注册
396 声望
创作了4篇指南
徽章: 12
+ 9更多徽章
CPSU-REGAN-F10S9G22
4 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 3,329
