跳转到主内容
Panasonic Lumix DMC-FX01 LCD Screen Replacement
你所需要的
  1. Panasonic Lumix DMC-FX01 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 LCD Screen Replacement, Rear Casing: 步骤 4 中的图像 1,1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 9 中的图像 1,2 Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 LCD Screen Replacement, LCD Screen: 步骤 10 中的图像 1,1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Gently tug the thicker ribbon to remove it from its housing.
结论
3等其他人完成本指南。
Andrew
于10/11/10注册
396 声望
创作了4篇指南
团队
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G22
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 17,265
