本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the front casing of your Panasonic Lumix DMC-FX01.
你所需要的
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
2等其他人完成本指南。
