跳转到主内容
Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement
你所需要的
  1. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 2 中的图像 1,1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Rear Casing: 步骤 4 中的图像 1,1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 6 中的图像 2,2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 9 中的图像 1,2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 9 中的图像 2,2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Flash Top Assembly: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Flash Top Assembly: 步骤 10 中的图像 2,2
    • Carefully pry the Flash Top Assembly away from the top.
  11. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 11 中的图像 1,2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 步骤 11 中的图像 2,2
    • Replace the Flash Top Assembly with a new one.
结论
Caleb Fink
于10/11/10注册
191 声望
创作了2篇指南
团队
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G22
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 3,807
