跳转到主内容
Panasonic Lumix DMC-FX01 Camera Lens Replacement
你所需要的
  1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 2 中的图像 1,1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Rear Casing: 步骤 4 中的图像 1,1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 6 中的图像 2,2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 8 中的图像 1,1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 9 中的图像 1,2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 9 中的图像 2,2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: 步骤 10 中的图像 2,2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  11. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 11 中的图像 1,3 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 11 中的图像 2,3 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 11 中的图像 3,3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  12. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 12 中的图像 1,1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
  13. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: 步骤 13 中的图像 1,2 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: 步骤 13 中的图像 2,2
    • Remove the three black 5mm screws attached to the lens frame.
  14. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 14 中的图像 1,1
    • Remove the lens frame.
  15. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 15 中的图像 1,1
    • Lift out the circuit board as shown.
  16. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 16 中的图像 1,2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 16 中的图像 2,2
    • Lift the two black latches that hold the connector ribbons in place.
    • Disconnect the two ribbons.
  17. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 17 中的图像 1,1
    • Remove the lens assembly as shown.
  18. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Camera Lens: 步骤 18 中的图像 1,1
    • Remove four 4 mm screws from the lens assembly using the Phillips #00 screwdriver.
  19. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 19 中的图像 1,2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 19 中的图像 2,2
    • Separate the fixed frame unit from the main lens assembly.
    • Separate the direct frame unit from the main lens assembly.
  20. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 20 中的图像 1,1
    • Remove the first lens frame from the lens assembly.
  21. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 21 中的图像 1,1
    • Detach the second frame unit from the lens assembly.
  22. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 22 中的图像 1,1
    • Remove the 4m m screw from the lens housing using the Phillips #00 screwdriver.
  23. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 步骤 23 中的图像 1,1
    • Separate the lens housing.
    • Replace the lens by gently prying away from the assembly.
结论
4等其他人完成本指南。
Caleb Fink
于10/11/10注册
191 声望
创作了2篇指南
团队
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G22
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 12,779
