跳转到主内容
Panasonic Lumix DMC-FH25 LCD Screen Replacement
你所需要的
  1. Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: 步骤 1 中的图像 3,3
    • Remove 5 screws attached to the back case using a 00 Phillips head screwdriver.
  2. Panasonic Lumix DMC-FH25 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Using your hands and a pry tool, lever the back case off.
  3. Panasonic Lumix DMC-FH25 LCD Screen Replacement: 步骤 3 中的图像 1,2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the back case.
  4. Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 2,3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 3,3
    • Using a 00 Phillips head screwdriver, remove a screw from the top right corner of the screen.
    • Lift the screen, being careful not to tear the ribbon cables on the right side.
  5. Panasonic Lumix DMC-FH25 LCD Screen Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Access the ribbon cables by removing the green button receiver panel using a plastic opening tool. There is a white panel beneath. Carefully remove this using a plastic opening tool. The white panel may require some elbow grease to get it off, and the panel may make a snapping sound as it comes off.
  6. Panasonic Lumix DMC-FH25 LCD Screen Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • One of the ribbon cables will be housed behind the screen and the other will be under the panels. Gently pull each free from the housing and remove the screen.
结论
2等其他人完成本指南。
Janice Weldon
于03/07/17注册
612 声望
创作了5篇指南
团队
一条评论
it has been quite easy tank you for sharing your help serge jobin
Serge Jobin - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 12
总计 448
