跳转到主内容
Panasonic Lumix DMC-FH20 Memory Card Replacement
  1. Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: 步骤 1 中的图像 3,3
    • On the bottom of the camera, move the gray switch that has the words "open" and "lock" above it to the open position. The case will open.
  2. Panasonic Lumix DMC-FH20 Memory Card Replacement: 步骤 2 中的图像 1,1
    • Once the case is open, you will see your memory card in the marked slot. Push the card down until you hear a small click. The card will then pop out and you will be able to remove it.
结论
团队
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 281
