跳转到主内容
Panasonic Lumix DMC-FH20 Circuit Board Replacement
你所需要的
  1. Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 3,3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 Circuit Board Replacement: 步骤 3 中的图像 1,2 Panasonic Lumix DMC-FH20 Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
结论
团队
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 321
