简介
If your camera will not charge or if the battery is broken, try replacing the battery. You don't need any special tools to replace your battery. Be careful of battery leakages. In the case of battery leakage, be sure to clean the inside of the battery opening before inserting a new one.
On the bottom of the camera, move the gray switch that has the words "open" and "lock" above it to the open position. The case will open.
即将完成!
结论
