简介
Replacing the front case of your camera.
配件
无需配件。
  1. Slide the lock into the unlocked position to the right.
    • Slide the lock into the unlocked position to the right.
    • Use your finger to slide battery hatch towards the arrow sign.
    • Both battery and memory card should now be visible.
  2. Open battery hatch and the black cover to expose the battery compartment.
    • Open battery hatch and the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Pull the battery out and replace with a new one.
    • When putting the battery back in, make sure it is in the same orientation as before.
    • Close the battery compartment, and make sure the lock is in the locked position.
  3. Remove the two 2.8 mm Phillips screws as shown in picture.
    • Remove the two 2.8 mm Phillips screws as shown in picture.
  4. Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
    • Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
  5. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
    • Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
  7. Use a spudger to pry open the case from all sides. Use a spudger to pry open the case from all sides.
    • Use a spudger to pry open the case from all sides.
  8. Beware of the ribbon cable that is still attached when opening. Use your fingers to carefully pry off the back casing from the camera assembly.
    • Beware of the ribbon cable that is still attached when opening.
    • Use your fingers to carefully pry off the back casing from the camera assembly.
  9. Lay the camera on its front side./combine this sentence to the step below.
    • Lay the camera on its front side./combine this sentence to the step below.
    • Use Spudger tool to open the film strip locking mechanism and remove strip./No edits necessary.
    • Hold down on the camera's metal casing with one hand. Using your other hand, completely lift the back case off the rest of the camera, making sure the film strip separates./Make a picture for this step.
  10. Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
    • Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
    • The other three screws shown in picture were removed to take off the back case.
  11. Using Spudger tool, pry the front case from the camera's components. Use your fingers to carefully pull the back case from the front case. Cut the black and red wires connecting front case to the body of the camera.
    • Using Spudger tool, pry the front case from the camera's components.
    • Use your fingers to carefully pull the back case from the front case.
    • Cut the black and red wires connecting front case to the body of the camera.
    • Be careful nothing gets caught, and separate the front case from the camera.
    • To put the new front case back on, solder the wires of the new front case to the components of the camera.
结论
另外一个人完成了本指南。
Alex Penman
于2011年01月28日注册
463 信誉积分
创作了4篇指南
团队
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011 的会员
CPSU-REGAN-W11S7G35
4 名成员
创作了5篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 5
总计 644
