跳转到主内容
Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement
你所需要的
  1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Back Case: 步骤 3 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 7 中的图像 1,2 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: 步骤 9 中的图像 1,2 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: 步骤 9 中的图像 2,2
    • Use a spudger to lift the screen ZIF connector tab.
    • Use the back of the spudger to push the ribbon cable free.
  10. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 10 中的图像 1,3 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 10 中的图像 2,3 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Use the screwdriver to remove the four 2.4 mm Phillips screws.
    • Lift up the LCD screen from the front case.
    • Potential for device damage: The wire is still connected to the board in the other side.
  11. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the LCD screen from its case.
  12. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Locate the wire connecting the LCD screen to the motherboard.
    • Use the soldering iron to desolder the wire.
    • Use the soldering iron to solder wires from new LCD screen to the circuit board.
结论
另外一个人完成了本指南。
Alex Penman
于01/28/11注册
463 声望
创作了4篇指南
团队
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011 的会员
CPSU-REGAN-W11S7G35
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 3,002
