跳转到主内容
简介
This is the replacement guide for the power port for the primary charging base of the device. If you've followed the troubleshooting guide for this device and have determined that this is your issue, look no further than this guide. Please make sure that the issue is with the power port before you begin, however, as this is not an easy replacement, and fixing the issue will require soldering.
  1. Panasonic KX-TGE233 Power Port Replacement, Base Front Panel Assembly: 步骤 1 中的图像 1,1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Power Port Replacement: 步骤 2 中的图像 1,1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Power Port Replacement: 步骤 3 中的图像 1,1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Power Port Replacement: 步骤 4 中的图像 1,1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Power Port Replacement: 步骤 5 中的图像 1,1
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 Power Port Replacement, Power Port: 步骤 6 中的图像 1,1
    • Now that the device has been opened, the power port can easily be removed from its resting point.
  7. Panasonic KX-TGE233 Power Port Replacement: 步骤 7 中的图像 1,1
  8. Panasonic KX-TGE233 Power Port Replacement: 步骤 8 中的图像 1,1
    • The faulty power port can now be detached from the device from its contact points. If soldering has been successful, removal should require minimal effort.
结论
Nico Cruz
于2016年02月09日注册
249 声望
创作了2篇指南
团队
IUPUI, Team 2-2, Baechle Spring 2016 IUPUI, Team 2-2, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S2G2
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 1,848
