跳转到主内容
Panasonic KX-TGE233 Handset Front Panel Assembly Replacement
你所需要的
  1. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Panasonic KX-TGE233 Handset Front Panel Assembly Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the handset over to expose the back panel, and slide the panel out to remove.
  2. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the two batteries by lifting up from one end.
  3. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement, Handset Front Panel Assembly: 步骤 3 中的图像 1,1
    • Remove the two screws behind the battery panel by using a Philips size #00 screwdriver.
  4. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: 步骤 4 中的图像 1,1
    • Using a spudger, open the device by starting from the bottom and working your way to the top.
    • This will require some force, so be careful not to break any of the wires inside of the device.
  5. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: 步骤 5 中的图像 1,1
    • Once the back has been separated from the rest of the device, carefully place it to the side. Be careful not to completely remove it, however, as there are wires connecting the back to the handset.
  6. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: 步骤 6 中的图像 1,1
    • Using the same screwdriver as before, remove the Philips size #00 screw holding the motherboard in place.
  7. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: 步骤 7 中的图像 1,1
    • With the screw removed, the front panel assembly can be separated from the rest of the device.
结论
另外一个人完成了本指南。
团队
IUPUI, Team 2-2, Baechle Spring 2016 IUPUI, Team 2-2, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S2G2
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 403
