跳转到主内容
简介
This replacement guide is for the primary charging base for the device. This base is where the answering machine is housed, and where the TEL line is connected. If the symptoms of your device indicate that you need to replace one of the components inside of the charging base, or you just need to give the front panel of the base a face lift with a newer piece, this is the guide you'll want to follow.
配件
没有特定配件。
  1. To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. With the screws removed, you can use a spudger to aid in removing the back from the device.
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. With the back removed, we now have direct access to all other components in the main docking station.
    • With the back removed, we now have direct access to all other components in the main docking station.
结论
Jesse Satterwhite
于2016年02月11日注册
607 信誉积分
创作了5篇指南
团队
IUPUI, Team 2-2, Baechle Spring 2016 IUPUI, Team 2-2, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S2G2
5 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 186
