跳转到主内容
简介
This guide will show you how to replace the front speaker of the Panasonic KX-TG6021M.
  1. Panasonic KX-TG6021M Front Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Panasonic KX-TG6021M Front Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Front Speaker Replacement: 步骤 2 中的图像 1,3 Panasonic KX-TG6021M Front Speaker Replacement: 步骤 2 中的图像 2,3 Panasonic KX-TG6021M Front Speaker Replacement: 步骤 2 中的图像 3,3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Front Speaker Replacement, Replace Phone Face: 步骤 3 中的图像 1,2 Panasonic KX-TG6021M Front Speaker Replacement, Replace Phone Face: 步骤 3 中的图像 2,2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Front Speaker Replacement: 步骤 4 中的图像 1,3 Panasonic KX-TG6021M Front Speaker Replacement: 步骤 4 中的图像 2,3 Panasonic KX-TG6021M Front Speaker Replacement: 步骤 4 中的图像 3,3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Front Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Front Speaker Replacement, Front Speaker: 步骤 6 中的图像 1,1
    • Remove the front speaker housing by detaching it from the circuit board.
  7. Panasonic KX-TG6021M Front Speaker Replacement: 步骤 7 中的图像 1,1
    • Pop out the front speaker from the housing.
  8. Panasonic KX-TG6021M Front Speaker Replacement: 步骤 8 中的图像 1,1
    • Desolder the two connections and remove the wires from the circuit board.
结论
paul scruggs
于2016年10月24日注册
177 声望
撰写一个指南
团队
IUPUI, Team 3-1, Baechle Fall 2016 IUPUI, Team 3-1, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S3G1
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 149
