跳转到主内容
Panasonic KX-T4000R Cordless Phone Antenna Replacement
你所需要的
  1. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: 步骤 1 中的图像 1,2 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: 步骤 1 中的图像 2,2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Panasonic KX-T4000R Cordless Phone Antenna Replacement: 步骤 2 中的图像 1,3 Panasonic KX-T4000R Cordless Phone Antenna Replacement: 步骤 2 中的图像 2,3 Panasonic KX-T4000R Cordless Phone Antenna Replacement: 步骤 2 中的图像 3,3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: 步骤 3 中的图像 1,2 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: 步骤 3 中的图像 2,2
    • Find the silver screw located in the red circle.
    • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  4. Panasonic KX-T4000R Cordless Phone Antenna Replacement: 步骤 4 中的图像 1,2 Panasonic KX-T4000R Cordless Phone Antenna Replacement: 步骤 4 中的图像 2,2
    • Press the release button.
    • The release button is located in the red circle in the image to the left.
结论
Elizabeth Kelly
于10/22/12注册
501 声望
创作了5篇指南
团队
Clemson, Team 15-1, Benson Fall 2012 Clemson, Team 15-1, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,844
