跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Once the back cover has been removed, removing the antenna is as simple as unscrewing one screw.
配件
没有特定配件。
  1. Orient the phone so that the phone model and other descriptive information is facing upward. Locate the two silver screws near the hinge where the battery is housed.
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Pull off the back panel of the phone. Make sure you pull the cover off carefully in order to prevent damage to the back cover. Make sure you pull the cover off carefully in order to prevent damage to the back cover.
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Find the silver screw located in the red circle. Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
    • Find the silver screw located in the red circle.
    • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  5. Press the release button. The release button is located in the red circle in the image to the left.
    • Press the release button.
    • The release button is located in the red circle in the image to the left.
结论
Elizabeth Kelly
于2012年10月22日注册
501 信誉积分
创作了5篇指南
团队
Clemson, Team 15-1, Benson Fall 2012 Clemson, Team 15-1, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G1
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 8
总计 1,448
