跳转到主内容
Panasonic KX-E603 Printwheel Replacement
  1. Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: 步骤 1 中的图像 1,2 Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: 步骤 1 中的图像 2,2
    • Open the lid of the typewriter.
  2. Panasonic KX-E603 Printwheel Replacement: 步骤 2 中的图像 1,2 Panasonic KX-E603 Printwheel Replacement: 步骤 2 中的图像 2,2
    • To release the green locking lever, pull it towards you.
  3. Panasonic KX-E603 Printwheel Replacement: 步骤 3 中的图像 1,2 Panasonic KX-E603 Printwheel Replacement: 步骤 3 中的图像 2,2
    • Gently lift to remove the old ink cartridge.
  4. Panasonic KX-E603 Printwheel Replacement, Printwheel: 步骤 4 中的图像 1,2 Panasonic KX-E603 Printwheel Replacement, Printwheel: 步骤 4 中的图像 2,2
    • Firmly grasp either one, or both of the plastic printwheel ends protruding from the carriage as seen.
    • Gently lift the printwheel while slightly pushing forward to remove the printwheel from its housing.
结论
To reassemble your device, follow these steps in reverse using your new printwheel.
Lindsay Stratis
于04/08/15注册
491 声望
创作了4篇指南
团队
Cal Poly, Team 17-1, Forte Spring 2015 Cal Poly, Team 17-1, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 397
