跳转到主内容
Panasonic HDC-TM90 Lens Clean
你所需要的
  1. Panasonic HDC-TM90 Lens Clean, Battery: 步骤 1 中的图像 1,1
    • Open the LCD screen.
  2. Panasonic HDC-TM90 Lens Clean: 步骤 2 中的图像 1,1
    • Slide the battery release switch away from the battery.
  3. Panasonic HDC-TM90 Lens Clean: 步骤 3 中的图像 1,1
    • While holding the switch away from the battery, push the battery out of the slot.
  4. Panasonic HDC-TM90 Lens Clean: 步骤 4 中的图像 1,1
    • Remove the battery from the camera.
  5. Panasonic HDC-TM90 Lens Clean, Panasonic HDC-TM90 Lens Clean: 步骤 5 中的图像 1,3 Panasonic HDC-TM90 Lens Clean, Panasonic HDC-TM90 Lens Clean: 步骤 5 中的图像 2,3 Panasonic HDC-TM90 Lens Clean, Panasonic HDC-TM90 Lens Clean: 步骤 5 中的图像 3,3
    • Remove 5 screws from the side panel body of the camcorder.
    • Use the spudger to remove the top of the camcorder.
  6. Panasonic HDC-TM90 Lens Clean: 步骤 6 中的图像 1,2 Panasonic HDC-TM90 Lens Clean: 步骤 6 中的图像 2,2
    • Unscrew three screws to remove the lens rim on the front of the camcorder.
    • Be aware of the wires attaching the lens rim to the body of the camcorder. You will not be able to separate the lens rim completely.
    • Use caution when separating the shutter lever.
  7. Panasonic HDC-TM90 Lens Clean: 步骤 7 中的图像 1,1
    • Remove the rubber ring around the lens.
  8. Panasonic HDC-TM90 Lens Clean: 步骤 8 中的图像 1,1
    • Unscrew the lens by removing the three screws connected to it.
结论
Tyler Jaynes
于02/01/17注册
1 声望
创作了2篇指南
团队
Baylor, Team 8-4, Whitney Spring 2017 Baylor, Team 8-4, Whitney Spring 2017 的会员
BU-WHITNEY-S17S8G4
3 名成员
创作了5篇指南
一条评论
Steps 1-4: good pre-req
Step 5-bullet 1: Which screwdriver and how many screws? There seem to be a lot of screws so perhaps numbering how many and where they came from would be helpful. Maybe color coding your steps with more details using markers of how many screws and what location in the pictures would be helpful.
Step 5 bullet 1 and 2 should probably be 2 separate steps.
Step 5- bullet 2: could use a picture
Step 6: Did not seem to be how we did this step at all. Perhaps this could be explained in much more detail with more detailed pictures. Also the cautions and warnings should be labeled as such.
Rene Klopf - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 493
