跳转到主内容
Panasonic HDC-TM15 Side Cover Replacement
你所需要的
  1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: 步骤 1 中的图像 1,1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Side Cover Replacement: 步骤 2 中的图像 1,1
    • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Side Cover Replacement: 步骤 3 中的图像 1,3 Panasonic HDC-TM15 Side Cover Replacement: 步骤 3 中的图像 2,3 Panasonic HDC-TM15 Side Cover Replacement: 步骤 3 中的图像 3,3
    • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
    • Once the old cover is completely detached, set it aside.
    • The inside of your camcorder should now be completely exposed, as seen in the photos.
  4. Panasonic HDC-TM15 Side Cover Replacement: 步骤 4 中的图像 1,2 Panasonic HDC-TM15 Side Cover Replacement: 步骤 4 中的图像 2,2
    • Line up the new side cover in the exact same place, ensuring that the screw holes match.
    • Re-screw the side cover into place.
  5. Panasonic HDC-TM15 Side Cover Replacement: 步骤 5 中的图像 1,1
    • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
    • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
结论
另外一个人完成了本指南。
Tricia Fallo
于03/11/15注册
210 声望
创作了2篇指南
团队
Marist, Team 1-4, Laflen Spring 2015 Marist, Team 1-4, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 325
