跳转到主内容
Panasonic HDC-TM15 Record Button Replacement
你所需要的
  1. Panasonic HDC-TM15 Record Button Replacement, Record Button: 步骤 1 中的图像 1,1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Record Button Replacement: 步骤 2 中的图像 1,1
    • Unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Record Button Replacement: 步骤 3 中的图像 1,3 Panasonic HDC-TM15 Record Button Replacement: 步骤 3 中的图像 2,3 Panasonic HDC-TM15 Record Button Replacement: 步骤 3 中的图像 3,3
    • Once all eleven screws have been removed, put your hand through the hand-strap and tug on the side cover until it comes off completely.
    • The inside of your camcorder should now be completely exposed, as shown in the photos.
  4. Panasonic HDC-TM15 Record Button Replacement: 步骤 4 中的图像 1,2 Panasonic HDC-TM15 Record Button Replacement: 步骤 4 中的图像 2,2
    • Unscrew the two 1 mm Phillips #00 black screws in the corners of the green memory card reader.
    • The screws should be surrounded by orange circles.
  5. Panasonic HDC-TM15 Record Button Replacement: 步骤 5 中的图像 1,1
    • Unscrew the black 1 mm Phillips #00 black screw in the left center beside the green motherboard.
  6. Panasonic HDC-TM15 Record Button Replacement: 步骤 6 中的图像 1,2 Panasonic HDC-TM15 Record Button Replacement: 步骤 6 中的图像 2,2
    • Unscrew the 1.2 mm Phillips #00 black screw beneath the motherboard on the bottom of the camcorder.
    • The green motherboard should now be partially detached, as shown in the photo.
  7. Panasonic HDC-TM15 Record Button Replacement: 步骤 7 中的图像 1,3 Panasonic HDC-TM15 Record Button Replacement: 步骤 7 中的图像 2,3 Panasonic HDC-TM15 Record Button Replacement: 步骤 7 中的图像 3,3
    • Remove the long silver plate that secures the record button.
  8. Panasonic HDC-TM15 Record Button Replacement: 步骤 8 中的图像 1,1
    • Remove the old record button from beneath the silver plate.
  9. Panasonic HDC-TM15 Record Button Replacement: 步骤 9 中的图像 1,2 Panasonic HDC-TM15 Record Button Replacement: 步骤 9 中的图像 2,2
    • Place the new Record button into the open slot.
  10. Panasonic HDC-TM15 Record Button Replacement: 步骤 10 中的图像 1,2 Panasonic HDC-TM15 Record Button Replacement: 步骤 10 中的图像 2,2
    • Slide the silver plate into place beside the new Record button.
    • Ensure that the Battery Eject button is lined up properly.
  11. Panasonic HDC-TM15 Record Button Replacement: 步骤 11 中的图像 1,2 Panasonic HDC-TM15 Record Button Replacement: 步骤 11 中的图像 2,2
    • Re-screw the green motherboard into place and re-attach the side cover to your camcorder.
    • When the side cover is securely fastened, you have completed the Record Button replacement of your Panasonic HDC-TM15 camcorder.
结论
Emma
于03/11/15注册
176 声望
撰写一个指南
团队
Marist, Team 1-4, Laflen Spring 2015 Marist, Team 1-4, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 261
