跳转到主内容
Panasonic HC‑VX870 Shoe Adapter Replacement
你所需要的
  1. Panasonic HC‑VX870 Shoe Adapter Replacement, Side Cover: 步骤 1 中的图像 1,3 Panasonic HC‑VX870 Shoe Adapter Replacement, Side Cover: 步骤 1 中的图像 2,3 Panasonic HC‑VX870 Shoe Adapter Replacement, Side Cover: 步骤 1 中的图像 3,3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Shoe Adapter Replacement: 步骤 2 中的图像 1,2 Panasonic HC‑VX870 Shoe Adapter Replacement: 步骤 2 中的图像 2,2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Shoe Adapter Replacement, Shoe Adapter: 步骤 3 中的图像 1,2 Panasonic HC‑VX870 Shoe Adapter Replacement, Shoe Adapter: 步骤 3 中的图像 2,2
    • Unscrew the indicated screw on the right side of the camcorder.
    • Unscrew the indicated screw on the back of the camcorder.
  4. Panasonic HC‑VX870 Shoe Adapter Replacement: 步骤 4 中的图像 1,1
    • Unscrew indicated screw on the inside of the left side of the camcorder.
  5. Panasonic HC‑VX870 Shoe Adapter Replacement: 步骤 5 中的图像 1,1
    • Remove the top cover of the camcorder by lightly lifting up on the back end of the top and tugging away from the lens (don't be afraid to use force).
  6. Panasonic HC‑VX870 Shoe Adapter Replacement: 步骤 6 中的图像 1,2 Panasonic HC‑VX870 Shoe Adapter Replacement: 步骤 6 中的图像 2,2
    • Unscrew the indicated screws and remove the piece they hold in place.
  7. Panasonic HC‑VX870 Shoe Adapter Replacement: 步骤 7 中的图像 1,2 Panasonic HC‑VX870 Shoe Adapter Replacement: 步骤 7 中的图像 2,2
    • Remove the shoe adapter by simply pulling it out of its place.
    • Be sure not to loose the tiny spring that is attached to the shoe adapter as you are removing it.
结论
Rebecca Maloney
于01/24/17注册
501 声望
创作了5篇指南
团队
Cal Poly, Team 13-6, Banghart Winter 2017 Cal Poly, Team 13-6, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 31
总计 1,127
