跳转到主内容
Panasonic HC‑VX870 Record Button Replacement
你所需要的
  1. Panasonic HC‑VX870 Record Button Replacement, Side Cover: 步骤 1 中的图像 1,3 Panasonic HC‑VX870 Record Button Replacement, Side Cover: 步骤 1 中的图像 2,3 Panasonic HC‑VX870 Record Button Replacement, Side Cover: 步骤 1 中的图像 3,3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Record Button Replacement: 步骤 2 中的图像 1,2 Panasonic HC‑VX870 Record Button Replacement: 步骤 2 中的图像 2,2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Record Button Replacement, Record Button Mechanism: 步骤 3 中的图像 1,1
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Record Button Replacement: 步骤 4 中的图像 1,1
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Record Button Replacement: 步骤 5 中的图像 1,3 Panasonic HC‑VX870 Record Button Replacement: 步骤 5 中的图像 2,3 Panasonic HC‑VX870 Record Button Replacement: 步骤 5 中的图像 3,3
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
结论
Rebecca Maloney
于01/24/17注册
501 声望
创作了5篇指南
团队
Cal Poly, Team 13-6, Banghart Winter 2017 Cal Poly, Team 13-6, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 460
