跳转到主内容
Panasonic ES2207P Battery Replacement
你所需要的
  1. Panasonic ES2207P Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove foil head and blades.
  2. Panasonic ES2207P Battery Replacement: 步骤 2 中的图像 1,1
    • Remove (2) 7.9mm Phillips #0 screws.
    • Remove (2) 14.3mm Phillips #0 screws.
  3. Panasonic ES2207P Battery Replacement: 步骤 3 中的图像 1,1
    • Push the blade mount assembly towards the rear of razor and remove.
  4. Panasonic ES2207P Battery Replacement: 步骤 4 中的图像 1,1
    • Be careful not to break any tabs that hold the panels to the body.
    • Remove both external panels using spudger if necessary.
  5. Panasonic ES2207P Battery Replacement: 步骤 5 中的图像 1,1
  6. Panasonic ES2207P Battery Replacement: 步骤 6 中的图像 1,1
    • This step may require a fair amount of force due to the O-ring.
    • Pull to separate the end-cap from the body.
  7. Panasonic ES2207P Battery Replacement: 步骤 7 中的图像 1,1
    • Remove (2) 7.9mm Phillips #0 screws and remove endcap from frame.
  8. Panasonic ES2207P Battery Replacement: 步骤 8 中的图像 1,2 Panasonic ES2207P Battery Replacement: 步骤 8 中的图像 2,2
    • Push forward on the lower terminal to remove the battery from the frame.
结论
4等其他人完成本指南。
Kevin Marvell
于11/06/17注册
309 声望
创作了2篇指南
团队
IUPUI, Team S6-G5, Baechle Fall 2017 IUPUI, Team S6-G5, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S6G5
3 名成员
创作了4篇指南
3条评论
Where to buy the battery? Can you provide more details?
Iurie Manea - 回复
Onde comprar bateria?
edie_engenheiro - 回复
super great job on the break down. Thanks
Jeff Harvey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 33
总计 3,300
