跳转到主内容
Panasonic ES-RF31 Battery Replacement
你所需要的
  1. Panasonic ES-RF31 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Panasonic ES-RF31 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Panasonic ES-RF31 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Loose the screw at the bottom part of the razor
  2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: 步骤 2 中的图像 1,3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: 步骤 2 中的图像 2,3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: 步骤 2 中的图像 3,3
    • Slide the cover from top to bottom
  3. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: 步骤 3 中的图像 1,2 Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: 步骤 3 中的图像 2,2
    • Loosen these eight screws
  4. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: 步骤 4 中的图像 1,2 Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: 步骤 4 中的图像 2,2
    • Insert an opening tool into the gap
    • Gently remove the battery cover
  5. Panasonic ES-RF31 Battery Replacement, Removing the Battery: 步骤 5 中的图像 1,2 Panasonic ES-RF31 Battery Replacement, Removing the Battery: 步骤 5 中的图像 2,2
    Very good, sehr gut
    Frank D - 回复
结论
7等其他人完成本指南。
Daniel
于07/06/15注册
934 声望
创作了2篇指南
团队
iFixit EU Team iFixit EU Team 的会员
Staff
46 名成员
创作了1,094篇指南
4条评论
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Nils Kay - 回复
Hello Nils!
Thanks for the hint.
Glad to hear that your razor works again!
Greetings
Daniel - 回复
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
Виктор Богачёв - 回复
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
David Paul - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 91
总计 5,832
